I`m hoping someone has the knowledge to advise me on this issue please. I`ve got a 2005 Ford with filthy PS fluid which needs replacing. My Ford handbook says the fluid spec is WSA-M2C-195-A.
I can`t even make out the original colour this might have been – the fluid looks like a powdered graphite cocktail!
I`ve got about a gallon of this stuff:
Febi 08972 Power steering oil Mercedes 00098988 which is described as oil based. The bottle has application recommendation as:
Dexron II
Voith 55.6335 (standard drain)
ZF TE – ML 09, 11, 14A,03D, 04D, 17C
I have found an application/cross reference for PS fluids
https://bevo.mercedes-benz.com/bevolisten/236.3_en.html
which gives the Merc fluid as being compatible with Fuchs Titan PSF.
The data sheet for the Fuchs from
http://www.generaloils.net/PI_TITAN-PSF_e.pdf
says it is `miscible and compatible with
conventional branded power steering fluids`.
So although this is a sort of step removed from a direct match I`m hoping I can go ahead & use the Febi fluid for a clean start in the Ford.
If I do a complete drain, seafoam flush & refill can I use the Febi in the Ford system with no danger to seals etc?
I`ve has a little experiment in a glass & the Febi mixes completely with a small sample of the dirty fluid.
I`m hoping this makes sense & you can advise.
Many thanks if you can assist, Julian
Dexron II
