Anyone use this stuff before? Walmart and AAP have it on sale. I did a few searches and couldn't find anything on here, I'm gonna give it a try in the next few months.
Yes and no. It will remove embedded iron particles.Is this an alternative to Claying?
You do it before claying. I wash 1st, iron remove second, wash again, claybar, wax and then go insane.Is this an alternative to Claying?
I'll use it WHILE claying as the lube. Kill two birds with one stone.Is this an alternative to Claying?
I prefer not to play chemist.Probably cheaper to just buy some oxalic or acetic acid and make your own (add a little detergent). Acetic acid is also known as vinegar.
Yes, just marketing. It's not much different. Doesn't smell as terrible FWIW.how is this different that iron-x?
where is the clay? or is that just marketing that you can skip clay barring.
Then don't spray on any iron cleaner product as they are acid too.I prefer not to play chemist.
Repainting a car is expensive.
I'll pay the markup for a fully formulated product, backed by a company's reputation.Then don't spray on any iron cleaner product as they are acid too.
It is, just chemistry, like saying I prefer not to play auto detailer!
Realize these products often have a roughly 1000% markup over what you can easily mix up at home. Out of principle alone I'd never pay that price, kinda like highway robbery for the uninformed customer.
You blend your own motor oil?
Iron remover actually creates rust that expands the embedded iron particles and removes the sharp spikes in the iron then when washed off loosens the iron. Thanks… Try a plastic bag on your hand on dry paint, before and after. You will be able to feel the contanimation.Then don't spray on any iron cleaner product as they are acid too.
