Mechanical oil pressure gauge problem
Up State NY
So I installed a mechanical oil pressure gauge on my Grand Am today. But it only reads 40 psi, if I rev it it slowly moves up a few psi then slowly goes back down. Is it possible I installed it wrong at the block? IE pushed the nylon tube too far into the fitting? It's not the gauge because I also tried the gauge out of my Z28, same thing.
Could be over-dampened. I had no dampening in my 17 year old cadillac and it twitched and tweaked at idle... which many would find disconcerting. So they put a glob of heavy grease on the needle.
The the same gauge moves fine on one vehicle and slowly on the other? Is this a dash mechanical gauge? Have you tried a test mechanical gauge? That would be my starting point.
i have found out the hard way to ONLY uses steel break line tubing for a oil gauges. if you use the things that most people use you can have a failure. been there done that.
Could be reading correctly. Just reving motor doesn't change pressure much. How does it do with driving at different rpms? And when engine gets hot and idles?
I agree that plastic tubing might be a problem, make sure it is routed away from any heat (manifold, etc). If it gets a hole or melted, there goes your oil !
Thanks for the help guys, the car spun a bearing tonight.
perhaps the gauge was quite accurate? sorry about the bearing.
I installed an electronic sunpro in our minivan 6 months ago. the sender just cr@pped out last weekend.
Braided line works well as well FWIW. I used copper tubing on mine without issue.
The engine flexes a jillion times relative to the car's interior. Metal lines fatigue and break.
Plastic is best. Maybe use some metal for a short run if the sensor is by a hot component, then tie it to a flexible one.
This is why no factory ever used all metal lines. There is always a flex line to the brakes, clutch, etc..
Plastic lines can melt and burst. Ask me how I know.
Seconded. Hot engine oil squirting on your leg from under the dash isn't pleasant.
Braided stainless is the way to go.
GM light and medium trucks of the 70's and 80's did. They were steel tubing.
I have also experienced the joy of running hard and fast and then getting burnt by hot oil. It can really ruin your day!
I remember a 70 Chevy pickup with metal line for the oil pressure gauge. IIRC it had about 6 coils in the line to either absorb the vibration, flexing, dampen or all of these i don't know.
