I have a 2006 Mazda 6 with the 3.0 Ford Duratec engine. I have had intermittent issues with the engine temperature running warmer than usual. I have a scangauge and the coolant temp usually levels off at 192 and only goes over that in the summer. Here recently it will go as high as 202 before working its way back down, sounds like the stat is a little sticky. I went to replace it and the stat says 188 degrees on it. The Superstat from Advance Auto parts advised a 195 operating temperature is what the car specs for. Is going above the factory stat of 188 adviseable and go with a 195 or should I go with the OEM? The OEM is very thin and flimsy looking, the superstat looks to be much higher quality. Any advice?
Thanks!
Thanks!
