Manual transmissioned electric car
Texas
Check you tube for conversions of ICE cars to electric . Most of the time , I do not really think the tranny is needed . Especially if the motor is wired so it can run in reverse , also .
MN
Originally Posted By: mjoekingz28
Is there any merit or possibility to this?
Not usually. Tesla's, Leafs, etc., these days only have a 1-speed, fixed gear, no torque convertor needed either. No clutch needed of course! Electric motors make full torque at near-zero RPM. (IC engines have very low torque near idle, so you have to put a bunch of gear changes in there.) A 2nd gear in an electric car can make some sense. You can get a higher top speed out of an electric car with a 2nd gear, but really that is solved by making the electric motor slightly larger, a cheaper & simpler solution than building a 2-speed gearbox. .... Not much shifting there to have your fun with if you did have 2 gears to play with. For example, my Ford Focus Electric is limited to 85 mph with its 1-speed due to motor overspeed concerns. If I had a 2-speed gearbox, I could probably get to 110 mph; Not worth it.
New England
Redneck it. Manual transmissions existed to solve a problem of a narrow power band with internal combustion motors. I don’t believe the issue exists with electric motors because torque and power are linear to one another.
Texas
I think I remember reading our 2012 Leaf was limited to something like 94 MPH . Never haf it to that speed . I always reied to conserve battery power / range . But it would get up and go , if you got in a tight and punched it . The conversions I watched on you tube often used a DC fork lift motor . If they had enough batteries to supply enough volts & amps ( watts ) they could break the home / custom made couplers / adapters .
MA, Mittelfranken.de
Not really. The more torque you have the less transmission speeds you need. Electric motors are torque monsters and if sized properly don't need any transmission at all just a step down differential.
Texas
In theory , most electric motors produce max torque at 0 RPM . And the least torque at max RPM . Some electric cars use an inverter to convert battery DC to a variation of 3 phase AC , I think . Best I remember , our late Leaf had 3 power conductors going to the motor . Which drove a reduction gear system . Reverse was achieve electrically by reversing the rotation of the motor .
Texas
To me , drift cars are a waste of time and money . But as long as it is some one elses time and money , knock your selves out .
USA
The Tesla Roadster originally had a 2-speed transmission, but they replaced them all with single-speed due to reliability issues with the 2-speed
KC
It all depends on the motor construction/design. There are some RPM limitations to electric motors due to both structural and electrical. You could probably save a bit of money on motor design if you mated it with a gearbox to reduce motor RPMs.
