I bought my truck new. Flushed ALL the fluids around 2k. As far as the transmission is concerned I’ve been using redline mt90 every 30k. I’m around 130k now. Last service I added magnetic plugs to the drain and fill. I’m a little concerned with the amount of metal on them. Anyways, wanted to see what you guys thought. The one on the right is the drain plug so it’s naturally holding more. I wiped the fill plug clean to give a comparison of how much metal it’s holding. They two plugs are identical.
