SHEAR is the reason...of course Mobil won't admit that. But you can see it somewhat by looking at the HTHS numbers, now that that have them posted.
If you mean shear is the reason the 0w30 delivers better gas mileage, as in it shears down in viscosity, which results in less viscous drag and better mileage, I respectfully submit that you are wrong. In the SAE paper by Mobil engineers (which has been mentioned on here numerous times), the 0w30 grade was the most shear stable of all the Mobil 1 grades.quote:
I find it very hard to believe that 0w30 Mobil 1 is more shear stable than their 10w30.quote:
It does seem counterintuitive, I know. But that's what the paper says. And despite the persistent rumors that Mobil 1 "always" shears out of grade, the more recent UOAs of Mobil 1 have shown this not to be the case. The LS1 5w30 test has shown absolutely NO shearing loss. In those cases where Mobil 1 has been shown to shear down, I would submit that they are isolated and ANY oil would have sheared under similar conditions.quote:
Jason, your response that the reason Mobil 1 0w30 gives the best gas mileage of any Mobil 1 was one word: SHEAR. This would indicate that you think the 0w30 shears in ALL applicatons, hence it gives better gas mileage in ALL situations. I was merely pointing out that your reasoning is flawed. There is plenty of evidence that any grade of Mobil 1 will shear in some applications, and that is true of any oil. But there is NO evidence that Mobil 1 shears out of grade in EVERY application.quote:
WRONG! For one a large, low revving, OHV V8 engine probably wouldn't shear a dino 5w60.quote:
Secondly if you think any oil will shear under conditions M1 will shear you are even more wrong. I was able to shear M1 out of grade, nearly 2 grades. But Red Line did't even budge more than a few tenths of a cSt.
If you want an even easier example try it in a Toyota V6. It will shear almost eveything. Try your beloved 0w30 in one and see what happens to it. They sheared Amsoil 0w30 quite nicely.
Cool!!quote:
0w30 oils aren't always just for cold climates though. In the case of the German Castrol, this is an oil that compares to most 10w30 in terms of it's summertime cold viscosity. What I mean is that it's viscosity at 40c, being 68.5, is actually the same or thicker than most 10w30s (M1 10w30 is 61.3cst at 40c for instane). So it's not like this stuff is thinner, just that when it gets super cold, it can flow better. So don't paint all 0w oils the same. Look at 0w40 Mobil 1 also, it's viscosity at 40c is 80.3, so it's not thin either, it compares to a lot of 10w40s out there. The 0w number scares a lot of people away, but it shouldn't. I wouldn't personally use 0w30 M1 though, even though it's viscosity at 40c is actually slightly thicker than their 5w30.
wow, nice stereotypical view of "oceanside." yes we have our surfers here but, they are just a small, small subculture. if anything, gangs and drive-by shootings have been a problem in oceanside. we also have a lot of street racers. low riders, street racers, gang bangers, surfers, skaters, gothic, rockers, ravers, etc. oceanside isn't as "beautiful" as the name sounds.quote:
Originally posted by MolaKule:
I suspect it is really Oceanside, California. You know, surfers, Beach Boys, tall blondes, woodies with surf boards on top, Annette Funicello....quote:
Excuse me but where in the heck is Oh-Shun-Syde, Killa Kali?
BTW, we DO have surfing here in Doo-Dah land. Gotta put some Schaeffer's 132 on my surf board before I go out on Saturday.
