I found the spec. on Mag1 0w20. What do you think of the moly #? How does the Mag1 oil compare to Mobil 1 afe, Mobil ep or Toyota oil. I'm going to use it in my wifes 2014 Toyota 2.5. After Toyota service runs out at 30 000.
Inspection Data
Specific Gravity @ 60°F (15.6°C) ASTM D4052 0.8512
Viscosity @ 40°C cSt ASTM D445 42.31
Viscosity @ 100°C cSt ASTM D445 8.06
Viscosity Index ASTM D2270 167
Pour Point °C (°F) ASTM D5950 -48°C (-54°F)
Color ASTM D 1500 2.5
Cold Cranking Simulator at (°C), cP ASTM D5293 5402 (-35)
High Temperature / High Shear Vis at 100°C, cP ASTM D 6616 5.87
High Temperature / High Shear Vis at 150°C, cP ASTM D5481 2.65
Noack Volatility, % loss ASTM D 6375 13.9
Calcium, wt. % ASTM D 5185 0.214
Zinc, wt. % ASTM D 5185 0.085
Phosphorus, wt. % ASTM D 5185 0.077
Sulfur, wt. % ASTM D 4951 0.333
Boron, wt. % ASTM D 5185 0.023
Molybdenum, wt. % ASTM D 5185 0.0079
Sulfated Ash, wt. % ASTM D 874 0.92
Nitrogen, wt. % ASTM D 4629 0.102
Pumping Viscosity at (°C), cP ASTM D4684 13,687 (-40)
Shear Stability ASTM D 6278 7.78
Foam Seq. I (Tendency/Stability), mL ASTM D 892 (Opt. A) 0/0
Foam Seq. II (Tendency/Stability), mL ASTM D 892 (Opt. A) 0/0
Foam Seq. III (Tendency/Stability), mL ASTM D 892 (Opt. A) 0/0
High Temperature Foaming, static foam ASTM D 6082 (Opt A) 40/0
Gravity, °API ASTM D287 34.74
TBN, mgKOH/g ASTM D 2896 7.9
http://www.mag1.com/ProductDetails.aspx?id=10c71b7e-9f62-4d63-851e-ec9de583cd3e
Inspection Data
