Originally Posted By: LeakySeals
They are not warped, thats pretty much a myth. Rotors get slick spots from the pads. Some time over the summer you had to slam on the brakes and come to a stop from high speed. The pads sat and fried on the surface of the red hot rotor, creating a slick spot. After that its grip, slip, grip, slip, thats the vibration you're feeling. No need to machine or replace. Just remove, clean, put back. Buy better pads maybe. Machining the brakes simply removes the slick surface. It also thins the metal, making the surface hotter, less dissipation for heat. So this pad glazing problem becomes worse.
