M1 Racing 0w30 ???? Old formula
virginia
I have a couple cases of the old M1 0w-30 Racing oil and was wondering if it was ok to use in my 07 Mustang GT w/ 24 valve 4.6 V8? This car specs 5w20. Im currently running M1 AFE 0w20 for either 6 month/ 7500k interval. Could the M1 racing go even longer?
Canada
It'll work, but if under warranty, I wouldn't do it. Not SM spec, and not right grade. Stick with what you are doing!
Jason2007
virginia
Well, the powertrain warranty will be up next March so I was thinking of using it starting then.
Jason2007
virginia
Canada
Good idea. It should do a minimum of 10k miles, its a good oil, and there have been UOA's on here that have shown it is a good long-drain oil.....
Texas
I would bet the engine will like. I've been using M1 5W20 in my 08 GT since new and just recently tried a run of M1 0W40! The engine seems to love it. I've run one tank of gas through it and the mileage was identical to the 5W20 mileage...imagine that. It sure does seem smoother and quieter so who knows.
NJ
I would use the 0w-30 racing oil as a ZDP spiker. Run the regular M1 5w20 and add a quart of the 0w-30 to raise the ZDP level. Just a thought.
Bad Axe, MI
Is it this stuff? M1 Racing 0w30(old formula) AL....0 CR....0 FE....1 CU....0 PB....0 SN....0 MO...73 NI....0 MN....0 AG....0 TI....0 K1....0 B....246 SI....3 NA....6 CA....2846 MG....15 P....1588 ZN....1602 BA....0 Visc....59.5 Flash....425 TBN....12.4
Bad Axe, MI
Ok i would cut it like buster said,shouldn't need full strengh,with the load of zinc it has one or two qts should boost another oil nice. glad i got 56qts of it.
