M1 MX4T 10W40, 1295 miles, Kawasaki ZZR250
OTTAWA, ON, CA
Oil was used for winter storage, put in the sump 23 October 2005, actually used from 9 April 2006-17 June 2006.
code:
Sample Date 5/17/2006
Analysis Date 5/20/2006
Lab WearCheck Canada
***Vehicle ID***
Make Kawasaki
Model ZZR250
Year 2004
Engine 248cc P2
Miles on Vehicle 9625
***Oil Identification***
Oil Brand Mobil
Oil Series Mobil 1 MX4T
Oil SAE J300 10W40
API SX SG/SH/MA
Miles on Oil 1295
Months In Service 7.8
***Elements***
Antimony Sb NR
Cadmium Cd NR
Vanadium V 0.1
Aluminum Al 8.8
Chromium Cr 0.6
Iron Fe 10
Copper Cu 3.4
Lead Pb 1.1
Tin Sn 0.5
Molybdenum Mo 71
Nickel 0
Manganese Mn 4.9
Silver Ag 0
Titanium Ti 0.1
Potassium K 0
Boron B 182
Silicon Si 5.8
Sodium Na 1.6
Calcium Ca 2173
Magnesium Mg 14
Phosporus P 1436
Zinc Zn 1484
Sulfur 2590
Barium Ba 0.1
***Viscosity***
cST @ 100 C 12.5
SUS @ 210 F NR
***Misc***
Flashpoint (F) NR
Fuel % 0.0
Antifreeze % NR
Water %
Insolubles % NR
Oxidation 63
Nitration 28
TBN NR
TAN 3.26
Ferrous Debris NR
Fuel Soot % 0
Glycol NEGATIVE
ISO Code NR
Additives None
URL NR
Notes Lab reports nothing, resample at next interval to monitor.
Location Ottawa, ON, CAN
***Filters used***
Air Filter Kawasaki OEM
Oil Filter FRAM CH6012
***Particle Count***
>2 micron NR
>5 micron NR
>10 micron NR
>15 micron NR
>25 micron NR
>50 micron NR
>100 micron NR
I don't know why everyone is so quiet, probably because this is such a good report. Considering all factors, namely that this was in the bike over the winter, all wear numbers are suprisingly low. It did get chewed up pretty bad though. Did they really test TAN and not TBN? I'd say stick with this oil if you don't mind the price, otherwise you could look around for something more reasonably priced.
Thanks for the comments nicrfe1370.
Yup, Wearcheck tested for TAN and not TBN.
I'm not sure of the city/hwy breakdown for the OCI. The girlfriend lives 6 miles away, so there's a bunch of short trips on it. Then there's also weekend secondary highway rides anywhere from 40 minutes to 5 hours duration.
I bought the oil last summer on sale, I've got enough for 3 more changes so for now I'm not concerned with the price [1.9L sump capacity helps].
Viscosity is a borderline 40. It lost what, 9.5% of the original viscosity [13.8 down to 12.5]? However, shifting felt awesome throughout the OCI.
FWIW I think my riding style is relatively tame. Average fuel economy for the OCI was 66.34 US MPG, or 3.55 L/100KM. The engine will see anywhere from 5-11,000RPM depending on traffic situations [redline is at 14,500RPM]. Normally no greater than 9,000RPM. Cruising RPM usually depends upon the speed limit and traffic situation, from 5-8,000 RPM [approximate highway cruising in 6th : 6250RPM = 50MPH/80KPH, 7000RPM 56MPH/90KPH, 7700RPM = 62MPH/100KPH].
