Code:
Vehicle 1990 Saab 900, 2.0L 16v I4 (N/A)
Miles on engine 240,087
Oil type Mobil 1, 0W-40 & 15W-50
Miles on oil 20,013
Time on oil 12 months (03.Nov.07 – 01.Nov.08)
Oil capacity 4 qts
Oil added 4.2 qts
Oil filter Purolator PureOne, PL10017, not changed during OCI
Air filter K&N drop-in, last cleaned at 150,000 miles
Driving Use 40% city, 60% hwy (by distance); 60% city, 40% hwy (by time)
Sampling method Vacuum pump via dipstick fill tube
Copper 8
Iron 14
Chromium 1
Aluminum 4
Lead 5
Tin 0
Molybdenum 80
Silicon 27
Sodium 8
Potassium 3
Calcium 2555
Magnesium 17
Zinc 1180
Boron 113
Phosphorus 1001
Water Neg
Glycol Neg
Viscosity 18.3
Soot 0
Sulfur 34
Oxidation 36
Lab S.O.S. Fluid Analysis, H.O. Penn Machinery
My previous 20,000 mile UOA using M1 0W-40/15W-50 & ACDelco PF13 filter
A repeat run of combined M1 oils, with the only difference being the choice of oil filter. Like last time, I started out with a 50/50 mix (2 qts ea) of M1 0W-40 & M1 15W-50 EP. At first I alternated, adding a bit of 0W-40, then a bit of 15W-50, then going back to 0W-40, etc. I did that for the first two additional qts. After that, the weather was again warm enough to top up just with 15W-50. The oil loss/consumption on this OCI averaged about the same 1 qt every 5k miles as the previous one. Also like last time, I knew this run was going to complete in about a year, so I didn’t bother changing the oil filter.
I installed new NGK copper plugs at the same time that I changed the oil, regapped them after 10k mi & replaced them at the end of the OCI. At 228k I replaced the O2 sensor. At 237k I replaced the water pump & refilled the coolant lost during the change. All other repairs were unrelated to any engine oil abuse.
At the end of this OCI, I finally cleaned & re-oiled my K&N air filter. It had 90k mi since the last cleaning & looked every bit as nasty as you might expect. I'll try to get the pics uploaded (as soon as I can find my new storage location!) & linked over to here.
Since the only difference between this OCI & the last was the different oil filter, I'm going to stop using PureOne & switch over to standard Purolator filters to see how they compare. They look as close to the old UK-made PF13 as I can find, including the location of the pressure relief valve at the far/closed end. The newest US-made PF13 is shorter & now uses a minimal plastic internal frame instead of a perforated metal tube. (This might improve the flow, but I'm going to see what I get with the Purolator first.)
The car is now in the middle of a 10k mi A-Rx clean, after which it'll go thru a 10k mi A-Rx rinse. After that, I'll probably use a combination of M1 15W-50 EP & QS 5W-20 full syn.
Miles on oil 20,013
Oil capacity 4 qts
Oil added 4.2 qts
Copper 8
Iron 14
Chromium 1
Aluminum 4
Lead 5
Tin 0
Molybdenum 80
Silicon 27
Sodium 8
Potassium 3
Calcium 2555
Magnesium 17
Zinc 1180
Boron 113
Phosphorus 1001
Water Neg
Glycol Neg
Viscosity 18.3
Soot 0
Sulfur 34
Oxidation 36
