M1 HM or PU?
Would you use those oils in a motor with 83000? I'm pretty sure conventional has been ran in it. Just afraid of it using or leaking oil if I switch to synthetic...
Don't worry, you can switch to/from conventional and synthetic whenever you want and unless there is already something wrong with the engine, should experience no problems at all.
02 Kia Sportage religiously 3k
If you're only going to run the oil 3K, then don't waste your money on M1 or PU. Either increase your OCI or use any conventional that meets the specs required by your vehicle.
Ok sounds good. The only reason I was thinking about synthetic is because I drive short distances daily 4-6 miles.
