My 2007 Tahoe 5.3 specs 5W-30. It sits outside in Indiana winters so I ran M1 0W-30 this winter. It burned a quart of oil during a 7000 mile OCI (20% left on OLM). The truck had 110,000 miles on it at time of OC and has no apparent leaks. I decided to try something stouter within the M1 family.
When comparing specs provided by XOM, there is a huge variation in Phos and Zinc among the 30 wt oils. To refresh everyone's memory, here's how BITOG describes the function of these additives:
"Phosphorus
Used as an anti-wear, anti-oxidant, extreme pressure, and corrosion inhibitor additive. Concentration levels vary greatly depending on oil brand.
Zinc
Another anti-wear, anti-oxidant, and corrosion inhibitor additive also commonly found in bearing alloys. Concentration levels vary greatly depending on oil brand."
XOM claims the following Phos/Zinc content: 0W-30 = 650/750; 5W-30 = 800/900 (+23%/20%); 5W-30HM & 10W-30HM = 1000/1100 (+53%/46%).
That's a big swing in "anti-wear, anti-oxidant and corrosion inhibitor additive". I note that the HM loadings are the same as M1's vaunted 0W-40 product. Surely, a 50% increase in these important additives has an impact over the course of an OCI.
I chose 10W-30HM as my replacement oil which also has significantly higher viscosity than the other 30 wts at 40C and in the 150C HTHS test. It seems to me that this oil should be much "tougher" than AFE at least in terms of consumption. We shall see. Comments?
"Phosphorus
Zinc
