Is it a fact that M1 will keep a new engine cleaner (internally) than conventional oil?
quote:Dosen't really sound like a tightly-controlled scientific experiment. All you are doing is comparison of two random engines in different cars that may have or may not have a harmless coloration. Although dino oil in a turbo is not advised, were there any oil issues with the Saab? I believe you MUST consider economics when looking at a service issue. Why not have custom-blended NASA super-oil changed every day when $.89c dino every year or two will keep a car running fine? Economics. Is Mobil 1 worth twice or three times the cost of dino oil? Sometimes yes in a turbo or an exotic that is diffficult to service, mostly no. Depends on the application. Generally, twice-a-year with quality dino is better than once a year Mobil 1, imo. If somone wants to contest that assertion, fine. Just don't try to say the comparison is not an economic issue if you don't like the idea just because you wasted a bunch of money on Mobil 1.
150k miles in a Honda Civic... my Dad who has been a Saab guy,... I saw the that had about 125k...
quote:Yes. However, not particularly because of anything unique that Mobil puts in its formulation. If you compare mineral oils to synthetics - PAO (polyalphaolefin), diester, or polyolester - you find that the mineral oils themselves break down and leave behind varnish and other deposits. In addition the synthetics hold more contaminants in suspension. And, particularly polyolester, they are more naturally detergent. The only downside to the synthetics might be the presence of moisture (e.g., crankcase condensation) with the diesters and polyolesters, where I'd expect to see the mineral oil and PAO do a better job. Whether this translates into better gas mileage, longer engine life, or anything else is another question.
Originally posted by 05corollaLE: Is it a fact that M1 will keep a new engine cleaner (internally) than conventional oil?
quote:I should have been clearer. My observations were offered only as that -- just observations. This is certainly NOT evidence from which you can draw conclusions with scientific or statistical certainty. This observation is, however, suggestive of the results a lot of folks have had or seen is use or observation of syns and dinos in the real world.
Originally posted by Audi Junkie:quote:Dosen't really sound like a tightly-controlled scientific experiment. All you are doing is comparison of two random engines in different cars that may have or may not have a harmless coloration. Although dino oil in a turbo is not advised, were there any oil issues with the Saab? I believe you MUST consider economics when looking at a service issue. Why not have custom-blended NASA super-oil changed every day when $.89c dino every year or two will keep a car running fine? Economics. Is Mobil 1 worth twice or three times the cost of dino oil? Sometimes yes in a turbo or an exotic that is diffficult to service, mostly no. Depends on the application. Generally, twice-a-year with quality dino is better than once a year Mobil 1, imo. If somone wants to contest that assertion, fine. Just don't try to say the comparison is not an economic issue if you don't like the idea just because you wasted a bunch of money on Mobil 1.
150k miles in a Honda Civic... my Dad who has been a Saab guy,... I saw the that had about 125k...![]()
quote:Cleaner than most. In the past I have to say yes in general but not exclusive of all dinos. Today, maybe not as much as in the past, but inclusive of all dinos, still no, however more likely for most if not all OTC dinos it would. I have seen some cars that it did varnish up. A frineds truck has less than 100K and it is coated with varnish from M1 but he goes 10-15K per drain with no top-ups (and he needs to top up).
