Originally Posted By: LeakySeals
What other than weight is the difference between the 2?
They have completely different lists of certs and approvals for starters........
They are designed for very different applications.
They function differently as well. I have used 0w40 in numerous cars, but when I found that 0w40 didn't tame the bottom end metals in my FX45 (an engine with a history of bottom end issues), I tried switching to the 5w40 TDT. Did a great job on the bottom end metals and I was running 15k OCIs with it. Ran the FX 155k miles before trading her in on a FX50s (which CANNOT use TDT). I would only switch from 0w40 to TDT if you had bearing metals higher than you want, the 0w40 is a great oil for most engines.
I was going to try Rotella T6 in the FX, but never got around to it. Do a search on my username and you will hit a bunch of 0w40 and TDT 5w40 UOAs posted.
