My Volvo S60 R (5 cyl, 300 HP, turbo) is due for an oil change. I would like to use a readily available and affordable oil, so I will be switching to Mobil 1 (from Amsoil).
Thus, my choices are 5W30, 10W30, 0W40, and 5W40. All of the these viscositis are acceptable per my owners manual. However, my manual does recommend using an A3 rated oil, which only the 0W40 meets.
I regularly shop at Costco, which sells M1 5W30 and 10W30, and would like to avoid a trip to Walmart for the 0W40 or 5W40. However, if there is reason to believe that the 0W40 or 5W40 will be a much better choice, then I will go with one of the 30 wt oils at Costco. Note that I use FP and LC.
Given the above, is one oil a better choice for Chicago, using a 7,500 OCI?
