Hmm, I would have thought that the cams would go flat on a 4.6 if they ran dry.
I don't know how anyone can slam M1 right now. They must blind, stupid or brand loyalists of a different brand!quote:
Dr. T, You are always bad mouthing Mobil 1 which is one of the best oils on the market.
It is just fine, but it's not exceptional, that is correct. Mobil 1 is not the holy grail, like I pointed out this morning, it sure tends to show a high amount of iron in the UOAs that use it. I think it's corrosion fighting additives must be pretty weak.quote:
It's not the oil and Mobil 1 is just fine.![]()
Patman, I respect your opinions and knowledge but you have me stunned sometimes. There is no HOly Grail. How and why do you think Mobil 1 is not good at fighting corrosion? I use all brands of oil, but I think it's insane to think that Mobil 1 is not as good as Amsoil or any other brand right now. What are you people looking at to base these claims? And please dont say an "LS1" engine.quote:
As usual TS, great post. Hypothetical question: If Patman is right, which I dont think he is, would that suggest that Mobil 1 is too thin? Right now in it's current form, Mobil is using a decent amount of Moly, Boron and a ton of Calcium. This to me would be a good combination of EP/AW additives.quote:
Abnormally high valvetrain wear is normally from using an oil that is either too thin or has insufficient antiwear additives or both.
I agree and I'm guilty at times of this. Even though Redline's UOA's have been sketchy, I still bought a case for $90 bc I believe Terry and the other's about this oil. However, when you get others who constantly distort the truth , wanting .00000001 ppm of iron and claming M1 is too thin etc., you start seeing all of these new posters start questioning what to use. That is where I have a problem. Patman, I have to blame you partially for doing this. I think you spread a mass hysteria about Mobil 1 all over the internet.quote:
I'm afraid this forum is starting to head in the direction of may other forums I look at with modulators and older/senior members playing god.
True, metro. The valvoline thing was just an example. I just think that, as a general trend, a group III that performs well gets brushed off, while Mobil often gets the benefit of the doubt. Anyways, I don't want to rip Mobil 1 because I think it is a very good oil. I just wanted to provide a counter point to the claim that Mobil gets unfairly bashed. Heck, I may even go back to it if the German Castrol doesn't work out.quote:
Originally posted by metroplex:
Consistency is also very important.
If out of 300 Valvoline synpower UOAs, 20 are really good - then it means nothing if out of 300 M1 UOAs, 250 are good.
Generally speaking I haven't heard of any horror stories or problems with M1, and since it was $3.77/qt I decided to switch to synthetics in my 4.6
VeeDub,quote:
Originally posted by VeeDubb:
Heck, I may even go back to it if the German Castrol doesn't work out. But it would suck to have to return all that German Castrol![]()
