Universal averages show typical wear levels for the F150 300 6 after 3,300 miles use on the oil. Copper and lead (both from bearings) were really the only metals out of line compared to averages. Though the higher than average, we can't necessarily say that these readings show a problem deleloping, but they are worth watching. If you are noticing any loss of oil pressure, then it's possible a problem may exist. The 3.9 TBN shows plenty of active additive left. Due to wear, check back in just 5,000 miles on the next fill. Hopefully metals fall.
I ran this oil since last fall and ran it 2 days shy of one year with 6,465 miles on oil and 70,456 on truck. I haul firewood, water tanks 65-250 gallon, plow snow with it, and is my daily driver. All miles are 2 lane paved and dirt roads, NO highway miles to speak of. The oil, M1 was 10-40 High Mileage, is the SL version I got on sale at Walmart a while back at $9.00 per 5 quart jug. Oil filter was Motocraft FL-1A. Air filter is a Fram. The truck hasn't had a cat. for many yrs and has a true dual exhaust. The EGR valve is also plugged off. It's old enough to drink too.
Code:
alum. 8
chromium 2
iron 36
copper 22
lead 71
tin 6
moly 82
nickle 1
manganese 1
boron 132
silicon 12
sodium 15
calcium 3288
magnesium 30
Phos. 890
zinc 1166
sus Visco 210 73.9
cSt Visco 100 13.98
flashpoint 415
fuel 0.5
Insolubles 0.4
TBN 3.9
PS: Oh, I forgot... NO MAKE-UP OIL, NOT ONE DROP.
Code:
alum. 8
chromium 2
iron 36
copper 22
lead 71
tin 6
moly 82
nickle 1
manganese 1
boron 132
silicon 12
sodium 15
calcium 3288
magnesium 30
Phos. 890
zinc 1166
sus Visco 210 73.9
cSt Visco 100 13.98
flashpoint 415
fuel 0.5
Insolubles 0.4
TBN 3.9
