Here at VIR in VA running with Viperdays. First session out with M1 0w-40 and sure enough got over 300 in 15 mins again. Last track event a sebring it did the same. Oil pressure at idle and 300 was 29psi at sebring. This time when over 300 the oil pressure was only freakin 24psi.
So saw the Motul rep here and told him what the car is doing. He had some 10w-40 (nothing in a 30 weight) Stuff is $$$, retail is $26 for a 2 liter can. So he cut me a deal and did 1 can free when I bought 3 cans. Still over $9 a liter. Nobody had any redline 5w-30 or I would of went with that.
So changed the oil and filter. Motul has a funny smell. Almost a grape scent to it.
Drove the next session and got over 300 again but not as fast it seemed. But the oil pressure did not go below 27psi when over 300 so that was good. I guess this will hold up better to the heat, then the M1 0w-40.
Looks like I will be installing an oil cooler over the winter.
The motul guy said since this is a racing oil and not an extended drain, he said no longer then 4-5k miles.
