Aw, c'mon, humour me (note the extra "u").
I'm not reading-challenged, I just disagree with you, that's all. Here's why:
1. Wear (for real, measured by mechanical engineers doing their day jobs, not UOA's) is negatively correlated with HTHS.
2. HTHS is a blending target, just like KV100. Higher than necessary, it reduces fuel economy. Lower than necessary, it allows excessive wear. The SAE and ACEA specs try to find a balance, and the balance points are the minimun HTHS specs that have become the targets that blenders shoot for every time.
For Newtonian fluids, HTHS is just KV150 and it's surprisingly high compared to what we're used to. For instance, a Group I base stock with a VI of 100 and a KV100 of 8.9 (xw-20 territory) will deliver an HTHS somewhere between 3.5 and 4 (suddenly it's an xw-40). The only reason our favorite 5w-20 doesn't deliver this kind of HTHS is that it's made with various VII's and PPD's and other gunk blended into a low viscosity base that aims it squarely at 2.6. Any higher would forfeit the coveted API Energy Conserving label.
So that's my view of the world, and it's not just based on book learning, but also on running oil pressure vs oil temperature vs RPM plots with different oils in the same engine. My results from comparo runs of TWS 10w-60, Motul 300V 5w-40 and 10w-40 and GC 0w-30 were that they all produced plots that were more or less the same at any RPM above idle. At idle, the only variable that mattered was oil temperature, actually.
So that's why, in my West Coast world, RL 5w-30 is just a "more Newtonian" 5w-30 than OTC 5w-30's; it's still a "real" 5w-30 in every respect. It pumps like one and it flows like one. However, because the blender isn't making an OTC Energy Conserving product, its more Newtonian and delivers wear protection levels rivaling most xw-40's.
My Canadian friend you clearly don't yet understand the relationship between HTHS viscosity and kinematic viscosity.
A higher HTHS vis' is not "better" it just means the oil is thicker regardless of what the KV100 spec' might be.
That's why RL 5W-30 IS A 40WT oil in reality because a HTHS vis of 3.8cP is that of a 40wt oil. It's pressurized flow at all temp's is that of a 40wt oil.
In comparison to M1 0W-40 it is a heavier oil particulatly at temp's below 100C despite M1's higher kinematic viscosity spec's.
I pointed out the HTHS vs KV100 relationship to you in a recent thread on RL 5W-20 but I do it again. The following post explains why in more detail:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2001169&page=1
