this was my first full OCI with full E85. i run E85 24/7, current ethanol content around 80%. ran it short to get a base line. this OCI had more than the normal amount of WOT 4th gear pulls. in the process of remote tuning, and try to diag a boost issues that only arises at full boost and high RPM. i'm guessing that's where some of the higher wear numbers are coming from. i was bit nervous when i drained the oil, because it smelled of straight up ethanol. but everything looks to be in order. i'm going to go out to 3K per their recommendation. (400whp).
COmments:
A full run on E85 didn't affect the oils physical properties to any noticeable extent. The viscosity is well within range for 0/40 and the insolubles level shows a low amount of oxidized solids built up in the oil. E85 use shouldn't directly impact wear metals, but the increased power could lead to wear. Metals are a little higher than we've seen in the past after a shorter oil run, but nothing inceased enough suspect poor wear or a problem, either. The TBN is very strong thanks to the short run, Give 3000 miles a try for the next run.
i noticed the unverisal averages changed since my last UOA, so i threw them in there. is that normal in just an eight month period? some of them fell by half.
Code:
Oil Type: M10-40 Make up oil used: 0 Miles unit: 35,850 30.667k 24.879k Mileage oil: 1,850 3395 3417 Date: 1/18 7/16 5/17 AVG(5/17) AVG (1/18) Aluminum 5 2 3 4 4 Chromium 1 1 1 2 1 Iron 8 6 7 20 9 Copper 13 6 6 10 8 Lead 1 1 1 1 2 Tin 0 1 0 0 1 Molybdenum 89 66 60 77 74 Nickel 0 1 0 0 0 Manganese 0 0 0 0 2 Silver 0 0 0 0 1 Titanium 0 0 0 0 1 Potassium 4 0 1 1 3 Boron 194 201 49 136 51 Silicon 8 30 11 18 10 Sodium 5 6 4 4 29 Calcium 2814 2750 1098 2083 1839 Magnesium 18 24 585 387 433 Phosphorus 954 848 583 777 848 Zinc 1093 937 717 944 1007 Barium 0 0 0 0 0 SUS@ 210F 70.1 62.5 57.2 63-76 cSt @100C 12.99 10.93 9.42 11.1-14.8 Flashpoint 430 395 385 >375 Fuel % <.5 <.5 <.5 <2 Antifreeze % 0 0 0 0 Water % 0 0 0 0 Insolubles % .2 .2 .2 <.6 TBN 8.8 7 >1
