I have a 94 Miata "R" package. I recently removed the Aerodyne turbo (self contained oil system) because of seizure. So at this point, I am back to the stock setup with a stand alone engine management computer.
I went from having 300HP to 93, kinda ard to take
So in an attempt at slightly more power I put in Mobil 1, 0-20. The first thing I noticed is that the oil leaked out of each plastic bottle by the time I got home. I guess it really is thin.
Oil pressure is slightly lower than my previous oil, a 50% blend of 10-30 and 15-50 M1. The engine is ever so slightly more revvy and seems to require less throttle during cruise. But the big issue is that I cannot notice any more power and top speed did not change (105 indicated). Even the fuel economy seems to be unaffected by the change. I can generally bank on getting 265-269 miles per tank, when filled to the top. I am still very close to those numbers and have not been able to achieve 270 miles. I figured that a 2 or 3% change would result. I guess will let the oil remain for 2500 miles and do a UOA. Should be interesting.
What do you guys think about the protection afforded by such a thin oil. The Miata engine is long lasting and tough. But the thrust bearing can become an issue. I would guess the thin oil does not protect the thrust bearing as well.
Chris
[ July 20, 2003, 10:45 AM: Message edited by: Cujet ]
![[Smile]](images/icons/smile.gif)
