I hesitated to place my oil analysis on this motor because of a ring problem but i thought some might be intersted. Terry, feel free to comment if you like.
car is '97 Camaro SS w/ modded LT1 bored and stroked to 396 c.i. engine dynoed 485 hp and is a daily driver. 60/40 hiway to city driving. oil consumption was 1 qt. every 700 miles.
I used walmart oil filter w/ Redline and a Hard Driver filter w/ the Mobil 1 oil...
Dyson Analysis
Customer Name : Capria
Oil Brand/Weight : M1 0w-40 / RL 10w-40
Type Equipment : Camaro
Miles/Hours on oil : 3670 / 2635
Total Miles/Hours : 21000 / 17400
Results ppm/% Comments (blank=normal)
Wear M1 / RL
Copper 08 / 11
Iron 42 / 40 wear from thicker oils
Chrome 10 / 08
Lead 08 / 19 RL add
Aluminum 04 / 05
Silicon 14 / 20 difference is,RL add
Tin 02 / 04
Additives
Molybdenum 91 / 458
Sodium 12 / 14
Magnesium 02 / 04
Zinc 791 / 1100
Potassium 0 / 13 RL add
Phosphorus 662 / 956
Calcium 2320 / 2120
Physical Properties
Water negative
Fuel negative detection scale neg,trace ,pos
Antifreeze negative
Soot 13 / 18 some solids,condensation suspected
Oxidation 49 / 117 scale 0-199 24.5%/58.5 RL cleaning
Nitration 62 / 63 scale 0-199 both 31% normal for this beast in
winter
Sulfur 44 / 211 RL spiking FTIR,normal fuel sulfur
TBN 9 / 4 normal M1, reran RL and it is 4
Vis@100 C 14.8/14.6 both 40w
Final Comments : Iron wear climbing based on vis of oil used, all other wear
values normal.
Lead and copper increase are normal RL signature. Amazingly the thicker
40w 50w oils raise the iron
wear, best was Pennz 10w-30. Have no idea why RL dropped from 10 to 13 TBN
to 4.
Dyson Analysis
Wear M1 / RL
Copper 08 / 11
Chrome 10 / 08
Lead 08 / 19 RL add
Aluminum 04 / 05
Tin 02 / 04
Additives
Molybdenum 91 / 458
Sodium 12 / 14
Magnesium 02 / 04
Zinc 791 / 1100
Calcium 2320 / 2120
Physical Properties
Water negative
Antifreeze negative
winter
values normal.
to 4.
