this is the first run of regular (non-break-in) oil on my IO360-C1C6. as the engine still only has 100 hrs on it, i am not real worried about the silicon (although my A&P is checking the induction system).
Code:
Oil Filter--------champion
OIL AeroShell 15w50
hr IN USE ------ 47
MI/HR-ON-UNIT----- 100
ALUMINUM---------- 9
CHROMIUM---------- 5
IRON-------------- 22
COPPER------------ 31
LEAD-------------- 4439
TIN--------------- 2
MOLYBDENUM-------- 1
NICKEL------------ 2
MANGANESE--------- 0
SILVER------------ 0
TITANIUM---------- 0
POTASSIUM--------- 1
BORON------------- 2
SILICON----------- 15
SODIUM------------ 2
CALCIUM----------- 3
MAGNESIUM--------- 6
PHOSPHORUS-------- 927
ZINC-------------- 7
BARIUM------------ 0
SUS-VIS@210F------ 90.6
cSt-VIS@100c------ 18.13
FLASHPOINT-IN-F--- 455
FUEL%-------------
ANTIFREEZE%-------
WATER%------------ 0.0
INSOLUBLES%------- 0.3
TBN---------------
Originally Posted By: Blackstone
Tin, nickel, and insolubles all settled down nicely for you, and if you could get copper and silicon to do the same, we could give your engine a clean bill of health. As it is, things don't really look bad at all.
Most of the excess copper is due to the use of Aeroshell 15W/50, and switching to a different type of oil
should take care of that. Silicon may be harmless as well if you use any DOW-4 around the oil filter gasket.
If not, check the air filter/induction system for any problems. Also check the oil filter for metal just to be on
the safe side on copper and resample in 45-50 hrs.
application is the HyperCheetah, a modified Grumman Cheetah, with the IO360 and a C/S prop. the first time around the rebuilt cylinders on this engine lost all the crosshatching in 150 hrs. this time around we have Lycoming new nitrided cylinders.
Code:
OIL AeroShell 15w50
hr IN USE ------ 47
FUEL%-------------
ANTIFREEZE%-------
TBN---------------
