Hi
I was shopping for oil to service the auto transmission and transfer case in an 08 wrangler with 208,000 KM - new to my daughter. In case it matters it won't be seeing much if any off road.
I'm not loyal to any brand. The auto parts store I walked into happened to sell Lucas - a good brand, so I've heard. When I got to checkout I noticed that it is SEMI synthetic ATF. I asked about this and they said it "would be fine" - would mix with the old ATF, give good protection etc. As it was the only ATF they had in stock and it is Lucas, I bought it. (Lucas does make full synthetic ATF but only in 5 gallon pails).
After, I called and talked to a Lucas rep. They also said it would be "fine". Wouldn't need to be changed any sooner than a full synthetic, mixes with the old, takes lots of heat before breaking down (but they did admit not as much as full synthetic) etc. I've heard these wrangler trannys get on the hot side.
I'm wondering though if I should keep shopping. Should I believe that it's last as long and protects as well as full synthetic?
I'm in no big rush to change it and definitely don't want to be doing this again any time soon - and of course want to put in good stuff - best I can.
What do you think?
Thanks for the help.
