No, they are going to test phos retention. They have not come up with a limit, but the idea is to reduce the amount of phos leaving the oil while not reducing the amount.
Here, if you had bothered to read the very page you linked to. There is more to it than the pretty spider graph.
Quote:
For GF-5, Phosphorous has not been reduced from GF-4 (0.06% wt) due to potential wear concerns. As such, a minimum on Phosphorous content still exists. Additionally, a Phosphorous Retention Test is to be incorporated into GF-5 with the objective of minimizing Phosphorous leaving the engine and entering the After-Treatment Devices (ATD). Previously, only a chemical limit was used.
A Phosphorous Retention Test will measure the amount of Phosphorous retained in the lubricant in the engine using the current Sequence IIIG engine test. Currently, ESCIT recommends to ILSAC using the Sequence IIIG @ 100 hours for this test.
