Originally Posted By: tenderloin
I have Lucas 5W-30 in one of my Explorers. With over 5,000 miles on the oil, the level on the dipstick has not dropped. Not sure if there is a big difference with the 10W-30 but if 40% is remotely true something should have been happening.
Btw the engine is smooth, quiet and MPG is at least as good as the other synthetics I have used in this vehicle.
The NOACK test is done at 302 degrees (F) oil temp. If what I've read is correct, many street cars don't see 212 degrees (F) oil temp, which is considered to be normal operating temperature.
I wonder what the volatility of these same oils would look like at normal operating temp?
But if an oil is 40% volatile @ 302(F), would it still be significantly more volatile @ 212(F) than the other oils? Is that safe to assume?
Regardless 40% volatility @ 302(F) does not meet current GF-4 specs.
Also, it could be that you wouldn't notice that big of a consumption issue in normal street driving with 3-to-5k OCIs?
