Lubricant for P/S box conversion.
Need some advice. I'm converting the P/S box of 4x4 Nissan to be used as a idler arm. Input shaft has been removed as will gearing, only the idler shaft will remain. Should I use the gear oil or maybe engine oil for bearing lubrication opposed to the originally used ATF since there won't be pressurised lubrication any more? Tnx in advance.
Kristian
One place I used to work at had a bunch of gear boxes. Non pressurized and low speed operation. They had all those filled with Mobil 1 20W50 motorcycle oil, and never any issues, defects, debris, or shavings. About 10-15oz per gearbox, getting changed once in 5 years, unless an oil seal gives up earlier. Even in 5 years of 24/7/365 operation oil is still golden clean, just a darker shade of gold VS new oil. Lack of high temp and/or combustion byproducts help.
