I have a few old Craftsman pear head ratchets, US made with the internal C-Clip retainers holding the internals in. I took two apart cleaned and lubed them, put them together and the C-Clip will turn with finger nail pressure on one of them, but holds the wrench together. Prior it the clip was tight. I have internal and external pliers for these types of clips, and used the external pliers to spread them a bit, which helped a little. Most of my better wrenches plates are held together with Torx screws, so they're never an issue. Do you guys replace the internal C-Clips or leave the wrench with the clip easy to turn? I'm wondering if the wrench is going to fall apart under load. Thanks.
