My 98 Camaro SS is just about done getting it's engine rebuilt. The shop said they will fill it with break in oil, start it to check that everything is ok, let it come up to temp and then change the oil with Royal Purple.
How many miles should I go before I change it? Should I have that first change analyzed?
I plan on running Amsoil in it. (I had previously run M1, before I spun a rod bearing.) I drive the car about 100 miles a week or so. (I commute with it once a week 50 miles each way.) I also open track the car once or twice a month when the budget allows. (Not likely for a couple of months after paying for the rebuild.)
So which Amsoil should I run S2? 0W30 20W50?
Thanks,
Mike
