Fair call, and I agree. If by 0, you are talking F, as 20w50 conventionals worked OK down to -11C for the first half of my life.
Have been tempted in the past to use the 15W-50 or V-Twin as the basis of a dumbell like blend to make a super stout 40, by starting with a highly shear stable, low PP (for the V-Twin, or the Motorbike 15W-50), then using a lighter viscosity to cut it back to where I was targetting.
I'm thinking that a more robust, shear stable, low volatility base, thinned with an oil that's more shear prone, higher volatility, and VII lighter oil (and with xW-20s fairly well available at my local mechanic), the oil will if anything "fail" into an area of higher safety margin.
That or start with Delvac 1 in the first place.
