Originally Posted by SierraMan
OK Guys, thank you for all your insight and suggestions regarding my problem. Just to clarify, I did have the oil pressure sensor replaced last fall. The mechanic that did the work told me that the screen was in good condition (no signs of contaminants on the screen). I used the 5W20 oil because I thought it would result in easier starting at low temperatures.
Regarding my oil pressure at highway speeds (2300 RPM), the gauge reads around 40 psi (275 kpa) .
I will change the oil to 10W30 full synthetic and change the oil filter to the longer style (like a Fram Ultra) and post the results that I have.
I will also change out the thermostat as I find that it seems to take a very long time for the engine to reach operating temperature. Perhaps it is just a matter of a high mileage engine, but a change of thermostat may help?
Does anyone if there is a way to adjust the low idle speed on this engine? It currently runs at about 600 RPM, and I think that a slightly higher RPM would help to keep the oil pressure up?
Just to feed back since I asked the question on the highway oil pressure. My Gen IV 2008 6 liter indicates 40 psi at highway speed, and the hot idle is around 30 psi at 600 rpm. (Assuming the gages are correct). This is with 5w30 QSUD Synthetic and 180,000 miles. Just to check, is your engine really a 2005 or is it maybe a 2007. Also, do you know if it has AFM or not? Thanks.
