Originally Posted By: GreeCguy
As far as age playing a factor, I still think the open bottle of fluid illustration works in this situation. No one here would be comfortable using a 26 year old bottle of fluid that had been opened 26 years ago and then placed on the shelf to sit for 26 Rip Van Winkle years. Even a cheap person like me would not put it in my daily ride. It just so happens you have 12 quarts of 26 year old fluid that's been exposed to all the joys of operation over the last 2 and one half decades.
I'm just guessing, but even though the car is "old," it's not a beater and you'd like to get another 150,000 miles out of the ole gal. You're at the perfect time for a change.
The one heads up I can give you for the filter change is that in my two Oldsmobiles, the transmissions are the same. The filter fits into a metal fitting with a rubber gasket at the top, (it's like a short metal pipe that's flared on one end and has a rubber gasket/ring at the other). You get a replacement with the filter kit, but they are a bugger to get out and get back in. Pulling them out destroys them, (I had to collaspe mine with a screwdriver and a hammer) and then putting in the new one is a trick in itself, (I finally got mine in by tapping on it gently with a hammer using a large socket on the fitting to guide it in. I only did one, (the one on my car), but my daughter's van I just left the original in the tranny and only replaced the filter as the original fitting looked good.
When you do replace the filter, be prepared for more fluid to come out when you pull the filter, that was a surprise to me as I though I had drained everything. Thanks to that extra fluid, I came out from under my car looking like Fonzie on "Happy Days."
And you have had no issues after these cars had a service? slipping? going into neutral at times while waiting for a light?
I understand your point, I just don't want to swap the fluid all at once. Transmissions are mythical magical machines that use space technology that earthlings cant comprehend.
