Someone help me from beating it with a bat and setting it on fire. I've had the transmission out 5 times in the past 2 years for various problem's. Leak's, Diff pin went thru case, Bought one that was bad, You name it. Well the late last year I rebuilt the tranny because of the diff pin, Now it's leaking pretty good and i'm going to have to pull it again this weekend to see whats wrong. I have to say though I'm getting pretty good, I can have it on the ground in 45 minutes flat. But either the front seal went or the front pump bolts came loose again, But I'll find out soon.
I completly went through the engine at the first of the year with all new gaskets and seal's and even threw in a new oil pump and many many other new parts. Well no leaks till now. I think it's coming from up top . It leaked a quart in about 1100 miles when I wasnt having to add any.
I'm just so ready for another vehicle, I just hope this one hold's up till then.
