Hi, after several days of lurking and searching I've just registered and this is my first post.
I'm blown away by the level of expertise here and how seriously you folks take your oil. Not that I'm new to that sort of feeling...
It's time for an oil change again, and I am looking for a synthetic that is the thinnest and runniest at startup as I can get away with. My car is a '92 Maxima with some notoriously fragile variable valve timing hardware in the upper end. I bought the car used a couple years ago and it was in good health since the previous owner had changed the oil on a regular basis. The owner's manual specifies 5w30 for this model and people have theorized that getting clean oil up there ASAP is the best way to keep the things alive. So last year I went and changed the oil to Mobil 1 5w30 TriSynthetic. Soon aftwards I found out about 0 weight oils and because of the "0" designation I thought that it would be thinner when cold, and thus better for startups.
Reading a lot of the threads and posts here I found out about the "German" Castrol Syntec 0w30 and, thanks to Patman's info, bought some at a Wal-Mart. My problem is that afterwards I seemed to read info that suggested that maybe this 0w30 oil was actually heavier than M1 5w30 at average room temperatures. It seemed that kinematic viscostity numbers correlated to this property. Is this a fair statement?
I did a some research and this is a cut & paste from what I compiled:
Kinematic Viscosity @ 40*C (cst) Comaprison:
M1 0w40....................80.3
M1 0w30....................54.8
M1 5w30....................53.7
M1 10w30...................61.3
M1 15w30..................124.7
M1 Delvac1 5w40............95.0
Castrol Syntec 0w30........68.5
REGULAR OILS FOR COMPARISON
Esso 5w20..................47
Esso 5w30..................66
Esso 10w30.................71
Valvoline 5w30.............63
Valvoline 10w30............71
Pennzoil 5w30..............60
Pennzoil 10w30.............67
Quaker State 5w20..........45(!)
Quaker State 5w30..........64
Quaker State 10w30.........69
(sorry about the weird formatting - can't get it even!)
It looks like the Delvac1 that I thought might be "better" was too thick, and the Made in Germany Syntec 0w30 is actually closer in viscosity (when "cold") to a conventional 10w30. Is this right?
I also remember reading about how people commented on how thin the M1 5w30 seems compared to other oils, and the numbers above seem to support that. It's kind of funny that "0" weight oils scare people away because they sound too thin, since that's exactly what I'm trying to find (unless my reasoning on this is totally wrong
I've tried searching a lot about this issue, but couldn't really find a good answer to help my confusion on this. I currently have a jug of M1 SuperSyn 5w30 and 4 bottles of Syntec 0w30 sitting in the basement and I just need to know which one to return.
Thanks and sorry for the long post!
Brian
![[Smile]](images/icons/smile.gif)
![[Wink]](images/icons/wink.gif)
![[Confused]](images/icons/confused.gif)
![[Embarrassed]](images/icons/blush.gif)
![[Big Grin]](images/icons/grin.gif)
