What make and models make the most durable and longest lasting transmissions in the SUV segment behind V8 and high output V6 engines?
I'm thinking Toyota and maybe Nissan? I've seen many Toyota Sequoias with 300k+ with no maintenance and a few Armadas.
The Aisin A750 & A760 used in the Tundra/Sequoia are stout!
The Jatco RE5R05A 5 speed used in the Titan/Armada are very good unit & the only ones I've rebuilt are because coolant contamination.
ZF 8HP used by Chrysler are good & one of the best shifting units out there.
Ford 6R80 which is a ZF 6HP....Very good, I've built a few.....But it's either from running them low on fluid or putting to much power through them.
The GM 6L80E IS a well engineered unit, BUT....The Torque Converter is a weak point that can be mitigated with some custom tuning & bulletproofed with a custom converter along with tuning. AFM has to be turned off as part of the tuning process.
