Can anyone tell me what the chemistry and/or other practical issues are in using Loctite 518 anaerobic sealant in a manual trans rebuild? This is to seal the aluminum case flanges to a central steel mounting plate (machined surfaces). Since whatever (hopefully minimal) amount that squeezes out inside the transmission isn't supposed to cure, what are the implications of that getting into the gear oil? Is it harmless or might it gum things up? Or worse, clog oil passages etc? I don't have any experience with this stuff in that environment. All wisdom and experience on the issue is appreciated. Thanks!
