- Joined
- Jun 3, 2021
- Messages
- 830
I still don't understand why a spec oil needs a supplementary friction reducer added to it, especially right after you pour the new oil in to begin with.
It doesn't. This is a want not a need.I still don't understand why a spec oil needs a supplementary friction reducer added to it, especially right after you pour the new oil in to begin with.
Ok.It doesn't. This is a want not a need.
They don't. They market most of their oils based on approvals. They also market additives for those that want more friction reduction etc. I don't see the issue with this. They make a nice profit on those additives and if you don't want to use them, no issue, don't. I have used several b/c it's fun to try things to be honest...just like others here on BITOG that use oils WAY beyond what is necessary for their cars b/c they want to even though it's completely unnecessary to use anything beyond Supertech from Walmart. It's the same concept to me.Ok.
Why they even market their oils where you would feel a desire to boost the finished formulation.
Do they ever give specific and exact details on how much friction is reduced? I mean if it's (for example) a 10% reduction then one might be able to make some sort of value analysis vs. cost. But if it's more like 0.01% then that would make a difference.They don't. They market most of their oils based on approvals. They also market additives for those that want more friction reduction etc. I don't see the issue with this. They make a nice profit on those additives and if you don't want to use them, no issue, don't. I have used several b/c it's fun to try things to be honest...just like others here on BITOG that use oils WAY beyond what is necessary for their cars b/c they want to even though it's completely unnecessary to use anything beyond Supertech from Walmart. It's the same concept to me.
Someone has posted the Euro TUV testing for MoS2 that gave some specific info somewhere here.Do they ever give specific and exact details on how much friction is reduced? I mean if it's (for example) a 10% reduction then one might be able to make some sort of value analysis vs. cost. But if it's more like 0.01% then that would make a difference.
Product overload
MMO but skip the flush?Skip the flush, if you want to clean use hpl (or 1/2 cup of MMO)
AFAIK that is the only oil they offer with it. They state on the bottle for high mile engines and I doubt it contains very much MoS2.
Specifically designed for older engine designs with or without a turbocharger.
