So the number I'm looking for is going to be thousands of psi per sq in and will vary depending upon engine speed. Arriving at a exact final number would prove to be difficult to say the least. With enough time and research I could probably figure it out, but I don't have the time right now. At the nose it will decrease as speed increases, howerver at the flanks it will increase as speeds incease. I guess this is why engine speed is so important on run-in.
The reason for askng was I read somewhere there is a direct correlation of this pressure and the need to EP/AW add's to prevent scuffing. I'm sure there are also many other variables, I.E. film thickness etc. I was hoping to determne if an OTC SM oil would be sufficient for my semi-built stroker. That and I find it very interesting.
Anyways, thanks for all the help.
