Deepsquat,
Why not add some oil only containg PTFE after running a baseline with your favorite oil and see if it reduces wear metals.
PTFE: The only paper I have seen on PTFE's is by F. G. Rieck of Flouramics, "Variability of PTFE Colloidals in Nonaqueous Systems and Lubricating oils," LE of May 1987. The interesting thing about the paper is he never shows any engine results or wear tests using his colloidal mixture. In his 1980 patent, he states how the mixture is created, but again never shows any frictional or wear data or results of engine tests, although there are some references.
The problem with PTFE, assuming you can get it to bond to metal in a colloidal mixture, is that PTFE shears easily from the metal surfaces and goes back into suspension, not into solution, creating a gel. Back to the paper in LE, he shows a Scanning Electron Microsope (SEM) photograph at 50X magnification and he says in figure 15, "they [particles of PTFE] are only loosely bonded to the [wear scar] surfaces."
Moly: I have copies of at least 5 patents by Exxon and Mobil and Lubrizol covering various Moly additives and I can tell you the metal dithiocarbamates in oils are the best FM/AW additives around for boundary lubrication.
[ September 14, 2002, 01:38 AM: Message edited by: MolaKule ]
