As was mentioned, Chrysler Lean Burn engines ran very lean under light loading during the ~15 years they were in production. There were more cases of (relatively) benign head cracks between the valves (not into water) in the smallblocks than in the years before and after Lean Burn, but for the most part there was no damage that affected performance unless the control system failed and stayed lean under load (ever seen an exhaust valve with a pie-shaped burn from rim to stem? I have!) The system was pretty clunky because of 1970s electronics and the fact that active mixture control was being applied to carburetors, but it worked a lot better than its reputation, frankly. Even the first generation hardened valve seat heads held up fine under the added abuse.A question for the gallery: No-one has ever explained to me why aviation engines can run perfectly at lean-of-peak EGT readings and not suffer damage while it can be detrimental to automobile engines. Is it a compression ratio, octane, or RPM related thing?
I'm assuming that's at full throttle (max available manifold pressure) with the prop used to adjust rpm to get the percentage power you want?I own and fly a Cessna Cardinal RG (177RG). It's powered by a 200HP (real world power is prob 185HP) Lycoming angle valve engine, which is considered 'high compression' at 8.7 to 1. The airframe is relatively sleek with it's gear up and cantilevered wings (no strut). However, it's a generally underpowered package in cruise flight (at 8500 feet, my typ crz alt) and operation 'lean of peak' is a great way to go a lot slower. While other people may achieve better results, my bird achieves 143Kts in cruise flight, slightly rich of peak EGT, or peak power available. Operating at 50 degrees lean of peak drops speed to 125Kts, fuel flow goes from 10.5gph to 8.7gph. It also adds almost a half hour to my typical (one way) trip of just over 400 miles.
58.8 gal vs 55.7 gal (round trip) . Almost an additional hour's airframe and engine time operating LOP, per round trip.
To make matters worse, operating at lower power like that results in difficulty maintaining altitude when there are downdrafts, such as when flying around the small but thermally active Florida cumulus clouds. (lots of lift in the clouds and sink outside the clouds). As the airspeed drops WAY off trying to maintain altitude during areas of sink. Aircraft with more power to weight do far better during LOP operations. Heck, even the upgrade to the IO390 engine solves this problem for most Cardinal owners. (not available for my year airframe, otherwise I'd do it)
In my case, I find LOP operations so annoying that I simply can't bring myself to do it anymore.
Yes, full throttle and 2550 or 2600 RPM. Anything less is simply less power. 2700 RPM achieves nothing.I'm assuming that's at full throttle (max available manifold pressure) with the prop used to adjust rpm to get the percentage power you want?
Yes, many light aircraft engines now have individual cylinder head and individual exhaust temperature indications. This does help pilots to manage their engines and avoid limits. Well designed planes don’t generally need all that much with regard to In flight engine adjustments. My old plane simply goes to full throttle and stays there. During climb, I adjust the mixture to the placarded fuel flow numbers, ie. 15GPH at 4000, then 13GPH at 8000. (it’s pretty close even if I touch nothing) I only reduce the RPM a little at top of climb. Amazingly, it will be really close to the peak power cruise fuel flow, so I’ll only have to adjust a little. It might be 11GPH, and I’ll adjust to 10.5.Don't the engine have head temp gauges as to tune the fuel mixture? Been 30nnyears since I rode in a Cessna152.
Re read my poor grammar and words used,,,, can't multi task, but the settings then are engineer out for you? Which proves I don't know much about planes other than I know one when I see one.
