- Joined
- Sep 2, 2016
- Messages
- 344
I have a low sloping roof with 1.5" drains that connect to downspouts, like this:
I found two of them clogged with leaf/debris. On the first one, the actual drain hole was completely filled with leaf bits and debris, but was apparently still draining as the surrounding area was dry shortly after a rainfall. However, the second one had pooling water as the drain inlet was covered by leaves and not draining. Rainwater would flow over the edge of the roof in this location.
I was thinking of adding these leaf strainers on the drain inlets but was wondering if anyone had any feedback or experience? They are meant for downspout inlets in gutters and the reviews are mixed. They seem to cause gutters to back up and require more frequent cleaning, but not sure if that would apply to a roof drain application.
