Lawn mower battery works fine in car
Suburban Washington DC
I didn't have a correct fitting battery on hand, i.e. with top posts oriented in the correct position, for this Taurus that I took out of storage 3 months ago. Not spending $120-$150 for a direct fit battery when a $30-$50 used one works when it comes up online. Figured I try this Walmart $30 lawn mower battery I bought the week before for my Honda Insight. Works just fine as an interim battery and has always started even after sitting a week or more. Not saying it would work well at 0°F though.
NH
Not too surprised, if it is a gear reduction starter then the battery needs are low. For starting, bigger batteries are good for other reasons.
Upper Midwest
Yes as noted in the winter when the battery capacity is a fraction of what it is in warmer weather. Larger batteries also will provide the proper reserve capacity if the alternator should fail.
