They’re very friendly, they wave alot.I want to like the latest Fram Ultra Synthetic oil filter as of the time of this post (2023 January).
I want to use Fram Ultra Synthetic XG7317 filters for all my vehicles since it still has a rating of 99%+ efficiency @ 20 microns, and one of the highest filtration efficiencies of any filter at 15 microns and 10 microns.
But, I've read so many posts on this forum about how Fram was bought out by a company called "First Brands", who is repeatedly
cheapening the Fram Ultra synthetic oil filter to increase their profit.
Cost cutting resulted in:
[1] Removal of the wire backing, which is causing the filter pleats to be wavy instead of straight after only a few thousand miles of use.
[2] Moving from Synthetic Microglass filter media to a synthetic blend media with only a thin layer of synthetic media bonded to a Cellulose media?
Please correct me if I am wrong on this point.
[3] People finding fuzzy hairs all on the filter media (possibly from the Fram Ultra Synthetic filters made in Brazil).
The fear is that these fuzzy hairs could detach from the filter and mix with the engine oil, causing engine wear.
So, is Fram Ultra Synthetic oil filters still a 1st choice despite all the cost cutting, or should it be avoided due to the reductions in quality by "First Brands"?
Would I be better off using a lower efficiency OEM filter than to use a Fram Ultra filter if the Fram Ultra is infested with hairy fuzz or possibly harmful due to other cost cutting in the internals of the filter or filter media.
Thanks in advance for your insight and advise.
The factory filter that is blue is made by fram. I'm going to use up the FU and TG's and then maybe go to ST 20k if I knew the number, M1 or Royal Purple. Haven't decided yet. Any experience with what I'm looking at from anyone I'll gladly listen to.They’re very friendly, they wave alot.
https://www.oilfilter-crossreference.com/The factory filter that is blue is made by fram. I'm going to use up the FU and TG's and then maybe go to ST 20k if I knew the number, M1 or Royal Purple. Haven't decided yet. Any experience with what I'm looking at from anyone I'll gladly listen to.
I assume you mean the Honda filters for the car in your sig?The factory filter that is blue is made by fram. I'm going to use up the FU and TG's and then maybe go to ST 20k if I knew the number, M1 or Royal Purple. Haven't decided yet. Any experience with what I'm looking at from anyone I'll gladly listen to.
The WM nearest me is the same but the next one (3-4 miles further) which is in a slightly more rural blue collar area has them and a much better stock of oil and all automotive repair items…My WalMart never stocks the MP filters.
For some applications they are made in USA, for others they are made in Brazil, for others in Korea.My fram ultra filter says made in the USA not Brazil lol
Can you add a reason possibly?Hard pass……
Idea is to find a superb filtration filter and then stick with it for all my vehicles.
Since efficient filtration and high flow are usually inversely proportional, the only way to get both is to choose a filter with Synthetic media.
I wanted to settle on Fram Ultra filters for this, but my post is asking if all it's cost cutting negatives are a disqualifier for using it?
I’d vote for PENTIUS PXL. They are a solid choice and under $6 off AmazonI want to like the latest Fram Ultra Synthetic oil filter as of the time of this post (2023 January).
I don’t trust first brands. Why I have tons of OG ULTAS for Dakota and my 11’ Focus. Endurance is too risky tooI went back to Ultra Synthetic, after all the hoopla about the Champion-made ruffled bypass bracket letting unfiltered oil through. Yes they cheapened it but it still filters more efficiently than any other.
Wavy pleats I think are a non issue. We don’t know the history of the filters pictured. Was the engine started at -10 degrees & revved? Did they try to squeeze 20k miles out if it? Bottom line is it filters very well for a fairly low price. I have opened one, no light leakage around the bypass bracket, no wavy pleats.
One other observation I have made is after extended parking (3 months) the Endurance & Amsoil filters allowed so much drain back the lifters were empty. Even after cranking in flood clear for a good 20 sec some cylinders weren’t getting compression. This didn’t happen with the Ultra. I’m suspect of anything Champion made now. The Ultra looks nothing like the Champion products so I’m presuming they are not Champion made.
