Last time Craftsman Ratchet Oil Port
St. Louis, MO
I recently got a 1/4" Craftsman ratchet that has an oil port. It looks like a ball bearing that you can put oil through.
My question is, when did Craftsman last do that? I cannot find any information on this ratchet. I believe it is from the 60s.
Thanks
The ratchet still works perfectly. Ironically, there was almost no lube inside the ratchet when I took it apart. Lots of nasty grease. Teeth on the ratchet and pawl were still in great shape. I lubed the ratchet after cleaning and put it in my toolbox.
I have one or two of them. I use a little 3 in 1 oil, the tip goes in if you keep your thumb nail under it. IIRC I bought them in the mid 1970's.
I have a 1/2 drive ratchet with the oiler ball that I bought 1967. I oiled it every two or three years and it still works as good as new. It's nearly bulletproof.
