I know this is supposed to be car & truck oil filters, but Briggs, Kohler JD etc. use filters that fit many cars-
"Briggs type"
3/4" X 16 threads 8-11 PSI Bypass
Gasket 2.734"OD 2.430"ID 0.226" thick
Length" Wix Purolator Hastings Fram Kohler B&S Baldwin JD TEC MotorCraft AC
2.3" 57035 NA LF503 NA 2805001 492932 B7165 ? 36563 NA NA?
2.7" 51056 L35310 LF302 PH8172 1205001 ? B1410 AM125424 36262 NA PF2210
3.4" 51348 L10241 LF157 PH7575 5205002 491056 BT223 AM101207 ? FL793 PF53
4.8" 51516 L20195 LF134 PH3600 NA NA B243 ? ? FL400A PFL400A
I'm a participant on the GardenWeb forums, and I constantly see the same old argument about using the "proper brand" filter. If it's a Briggs, better use a Briggs filter unless the Briggs is in a John Deere than uh.....
My question is-
Does anybody know who makes the filters for these various companies? Any dissections out there?
At least one curious mind wants to know!
TIA
"Briggs type"
My question is-
TIA
