New here so bare with me. Working on a welder generator that is powered by a Kohler 12.5 command. Been sitting for years, got it to run on carb cleaner and die. Pulled carb to clean and went to inspecting a few other things. It was backfiring, pulled valve cover and rocker arms and push rods were fine. I also noticed an exhaust leak so while inspecting this I pulled muffler and found that where the muffler bolts to the head that around one of the bolt holes quiet a bit of metal was missing.
Could this be from Years of leaking exhaust gases?
Exhaust valve issues?
Possible blown head gasket?
I bought some extreme temp epoxy putty to possibly make a repair rather than replace the head
