I probably drive my 1988 Ford Escort XR3i a little bit too gently, it's my daily driver so it sees mostly just relaxed 50Mph highway cruising in 5th gear at 2000-25000rpm and city stop and go traffic.
The other day i decided to get a bit silly in an empty parking lot and noticed it makes a fairly nasty dieseling type noise when flooring it from low speeds, even in 1st gear, although only for maybe a couple seconds, i've always used 95 RON gas in it so i decided to fill her up with Shell V-Power 98 yesterday and the knock is definitely almost gone, i think i'll retard the timing a little too as i think it's a little too advanced perhaps, although i like running as much timing as possible because that way it idles nice and smooth.
The plugs look normal and are not worn or damaged, but i can see the top of the pistons look like they have a fair amount of deposits, i'll run a few tanks of V-Power through it and drive it a little more spiritedly to see if maybe it would clean up the deposits.
