I'm a little disappointed at the moment. My trusty downward firing Klipsch Sub-10 stopped working yesterday. I am on the fence about repairing it - new amp for about $250 or "upgrading" to a 12" Klipsch KSW-12. Now about the KSW-12 there are actually two of them as a matching pair, listed locally. Im really shocked about decent subwoofer prices! So i dont think im buying new atm. The KSW-12 are 200 a piece. What should i do? Repair the Sub-10 for $250, buy just one KSW-12, or the pair?.... Recommendations or suggestions on maybe something completely different but not astronomical on price.
I was very happy with the Sub-10 output. It was able to reproduce the most lowest frequencies, and sounded really nice, - I've gotten a few compliments about it actually over the years. But i currently have yet another Klipsch R-120SW 12" subwoofer hooked up as a temp, and it IMHO does not sound as good as the sub-10 so im thinking it has to do with the downward firing layout of the sub or speaker construction? Thanks!!
This is the Sub-10 that stopped working
The KSW-12
Type: 12" bass reflex, tuned port enclosure Amplifier: Peak output power 441 watts into 4 ohms
FTC Rated Power: 105 watts continuous into 4 ohms,
22-100Hz @ 1% THD maximum
Auto Power On: 2 second ON delay, 15 minute OFF delay Frequency Response: 26-120Hz±3dB
Maximum Acoustic Output: 113dB 1/8 space 1 meter
Low Pass Crossover: Continuously variable from 40-120Hz,
24dB/octave slope above 120Hz
Inputs: 2) Line level RCA phono jacks, 2) High level speaker
terminals
Outputs: 2) High level speaker terminals, High pass filtered
at 100Hz, 6dB/octave slope
Phase: Switchable 0-180 degrees
Drive Component: K-1071-K 12" (30.5cm) driver
Net Weight: 35 lbs. (15.9kg)
Height: 17" (43.18cm)
Width: 15" (38.1cm)
Depth: 15" (38.1cm)
Cabinet: Medium density fiber board construction (MDF) Finish: Matte finish black vinyl
Voltage: 110/120 VAC 60 Hz - Export Version 230
VAC 50/60Hz
And the temp R-120SW currently in use
The KSW-12
terminals
Width: 15" (38.1cm)
Depth: 15" (38.1cm)
VAC 50/60Hz
